I am working on a Tiva launchpad board and want to use the GPIO. I have successfully enabled the clock on PORTF using this line of code:
SYSCTL_RCGCGPIO_R = 0x20U;
So I tried changing the above line to the one shown below:
SYSCTL_RCGCGPIO_R |= (5 << 1U);
This did not work. Will someone explain the difference between the two.
  • \$\begingroup\$ This is all standard C syntax, which is well documented all over the internet. What exactly is confusing to you? \$\endgroup\$ Mar 23, 2019 at 14:43
  • \$\begingroup\$ @ElliotAlderson the first line works. If replace it with the second it fails. \$\endgroup\$
    – Rufusy
    Mar 25, 2019 at 8:08
Lets convert all of your integer values to binary for easier comparison.
    0x20 -> 0b00100000
    5    -> 0b00000101
(5 << 1) -> 0b00001010
I think you can already see the problem.
If, however, you did (1 << 5) instead, you'd have:
    0x20 -> 0b00100000
    1    -> 0b00000001
(1 << 5) -> 0b00100000
So, to sum it up, you need to shift 1 left by 5 bits, not shift 5 left by 1 bit.
