Consider the following
$$ H(s) = \frac{sR_2C_1}{1+s(R_1+R_2)C_1}$$ $$ f_z = \frac{1}{2\pi R_2C_1} $$ $$ f_p = \frac{1}{2\pi (R_1+R_2)C_1} $$
I simulated the circuit in LTSPICE with \$R_1=R_2=795\$ and \$C_1=1nF\$ which should give me a \$f_z = 200kHz\$ and \$f_p = 100kHz\$.
Here is the AC anaylsis of the simulation. enter image description here
Question: Given that there is a zero at the origin with a certain frequency - what should I see at that frequency ?
Additional information to add some clarity: I am reading this book about Linear Circuits and it says the following
$$ H(s) = \frac{sR_2C_1}{1+s(R_1+R_2)C_1} = \frac{\frac{s}{w_{z0}}}{1+\frac{s}{w_{p1}}} $$
where \$ w_{z0} = \frac{1}{R_2C_1} \$ and \$ w_{p1}= \frac{1}{(R_1+R_2)C_1} \$
I believe the intent of this form is to visually be able to extract certain information about the system. I am confused on the significance of the \$w_{z0} \$ and what it means.
Traditionally I have seen forms such as $$ H(s) = \frac{1+\frac{s}{w_z}}{1+\frac{s}{w_p}}$$ and I know that you have a flat line (magnitude plot) until the wz and then you have an +20db/dec line and then a -20db/dec at the wp. But this zero at the origin is messing me up.
  • \$\begingroup\$ The "certain frequency" you see at the origin is \$f = 0\$. Why don't you substitute \$s = 2 \pi f = 0\$, plug it into \$H(s)\$, and see what you get? \$\endgroup\$ – TimWescott Mar 23 '19 at 16:05
  • \$\begingroup\$ Sure I get a H(s) = 0. I understand that a zero at an origin means that at DC, H(s) is zero, (because s = 0). But what about the RC for the numerator ? What does it do ? \$\endgroup\$ – Frankie Mar 23 '19 at 16:11
  • \$\begingroup\$ The coefficient in the numerator (\$R_2 C_1\$) establish the high-frequency gain, along with the coefficient in the denominator. \$\endgroup\$ – TimWescott Mar 23 '19 at 16:15
  • \$\begingroup\$ "...Given that there is a zero at the origin with a certain frequency - what should I see at that frequency ?": A plot in dB will not show the gain in \$\omega = 0\$, since \$log (0)\$ is undefined. \$\endgroup\$ – Dirceu Rodrigues Jr Mar 23 '19 at 16:21
  • \$\begingroup\$ You need to factor numerator and denominator. Your equation for fz is incorrect. fz = 0, as Tim says. \$\endgroup\$ – Spehro Pefhany Mar 23 '19 at 16:29
The reason why you do not "see" the zero is because it lies at the origin, for \$s=0\$. You can see that when \$s=0\$, the numerator is 0 and so is the magnitude: the dc component is blocked by the capacitor.
There is actually a better way to write this transfer function because it does not provide insight on the high-frequency plateau. This form is called a low-entropy form, a term forged by the late Dr. Middlebrook some time ago. It implies that a transfer function linking a response (\$V_{out}\$) to a stimulus (\$V_{in}\$) must be preferably expressed in way where zeroes, poles and gains properly appear. In your case, you can advantageously factor \$sR_2C_1\$ in the numerator and \$s(R_1+R_2)C_1\$ in the denominator:
\$H(s)=\frac{sR_2C_1}{s(R_1+R_2)C_1}\frac{1}{1+\frac{1}{s(R_1+R_2)C_1}}=H_{\infty}\frac{1}{1+\frac{\omega_p}{s}}\$ in which:
\$H_{\infty}=\frac{R_2}{R_1+R_2}\$ and \$\omega_p=\frac{1}{C_1(R_1+R_2)}\$
In this expression, \$\omega_p\$ is an inverted pole and lets you shape the transfer function in this convenient way, with a leading term \$H_{\infty}\$ representing the plateau gain as \$s\$ approaches infinity.
This is the proper way of writing this transfer function. If you are interested by determining transfer functions in a quick and swift way, you can have a look at the fast analytical circuits techniques or FACTs for which an introduction is given here.
| improve this answer | |
  • \$\begingroup\$ I saw your answer in another post about FACTs. The book I am reading where the question was derived from was Linear Circuit Transfer Functions: An Introduction to Fast Analytical Techniques. I liked the link so much that I ended up buying a book and am working through it now but still have gaps - the notation / form in the question is actually taken from a FACTs book. \$\endgroup\$ – Frankie Mar 23 '19 at 17:29
  • \$\begingroup\$ Going through the FACTs and being fluent at them requires a little bit of time but once you master the technique, you won't go back to classical analysis! Feel free to post more questions if needed. \$\endgroup\$ – Verbal Kint Mar 23 '19 at 21:57
