I'm having a problem getting this GSM modem to work with an FPGA (Spartan 3). I've already implemented UART transmission on the FPGA side,the MAX232 to convert TTL->RS232, and 3.3V->5V logic level shifting to interface the FPGA with the MAX232.
I can see the messages sent by the FPGA on my PC (using the Arduino Serial Monitor) with this FTDI Breakout. I can also communicate with the GSM Modem by using the Arduino Serial Monitor to enter the AT command mode and send text messages.
When I send the same message from the FPGA to the modem,however, I receive an empty text bubble on my phone. I've double checked the baud rate settings, the string structure (including a Carriage Return at the end of every text message) and the TX(FPGA)->RX(GSM) wiring order.
I'm still uncertain of why the arduino terminal can communicate with the modem, but the same message sent from the FPGA doesn't transmit to my phone.
UART Settings: 115200 baud, 8 data bits, 1 stop bit, no parity, no flow control.The VHDL UART transmission and 115200Hz clock frequency generator component is shown below for reference.
EDIT: How the modem works:
The modem requires the use of AT commands to it either through SMS or Serial to configure it. I need it to simply send text messages so to do this I have to set the baud rate that the FPGA will use i.e. the default one of 115200Hz and the work mode i.e. SMS. Then exit AT mode and resume transparent mode. See pages 5 and 7 for a description of transparent mode and an illustration of the transmission process
This is done externally to the FPGA with the software that comes with modem to run on a PC. Once the parameters are configured, whenever the modem starts up it will start in transparent mode. So all that has to be done is send your text message and terminate with a carriage return character to signify end of text.
So the modem is in transparent mode and waiting for the text message data when it's connected to the FPGA. The modem does not transmit any data to the host (FPGA/Serial Monitor) when in transparent mode. It only looks out for the text message data in i.e. RX(GSM)
Baud Generator:
 clk_115200Hz : process(clk,reset,clock3_tmp)
        variable a3: integer range 0 to 217;
            begin
                if(reset='1') then
                    a3:=1;
                    clock3_tmp<='0';
                elsif rising_edge(clk) then
                    a3 :=a3+1;
                if (a3 = 217) then
                    clock3_tmp <= not clock3_tmp;
                    a3 := 1;
                end if;
            end if;
         clock3 <= clock3_tmp;
     end process;
Uart Transmit:
  uart_transmit: process (clk,reset)
     variable bit_count: integer range 0 to 9:=0;
     begin
        if(reset='1') then
            tx_line<=idle;
            bit_count:=0;
            TX_DONE<='0';
            elsif rising_edge(clk)then
                if(enable= '1')then
                    if(TX_READY = '1')then
                     if(bit_count=9)then
                        TX_DONE<='1';
                        tx_line<=idle;
                        bit_count:=0;
                     else
                        tx_line<=TX_MESSAGE(bit_count);
                        bit_count:= bit_count+1;
                        TX_DONE<='0';
                     end if;
                    elsif(TX_READY = '0')then
                     tx_line<=idle;
                    end if;
              end if;
            end if;
     end process;
  • \$\begingroup\$ Trying to do this with HDL code alone is unwise, managing a mobile data modem correctly really calls for a programmable core which can run software. And you can't just throw things at it, you need to monitor the responses and send only when these indicate it is in the proper state. \$\endgroup\$ Mar 24, 2019 at 2:28
  • \$\begingroup\$ @ChrisStratton I agree with you, however I'm a student and this is my project requirement so I don't really have the option to use a different way to control the modem. So I need to make this way work. But I'll look into what you mentioned, thanks \$\endgroup\$
    – SRR
    Mar 24, 2019 at 2:53
  • \$\begingroup\$ See uart is asynchronous logic w/o clock. That's why we need to set baud rate apriori. From your code, I can see that you are choosing baud rate = 115200Hz. The baud generator is counting till 217. That means you have set your clk = 25MHz (24.998MHz to be precise). Now, when I look at your uart_trnasmit logic, you are not at all using clock3. That's where the typo is! In uart_transmit logic, you should use clock3 instead of clk. Because right now your technically working at 25000000 baud rate. \$\endgroup\$ Mar 24, 2019 at 3:00
  • \$\begingroup\$ @SourabhTapas actaully one should not use divided clocks in an FPGA, rather the logic should use the DLL (or whatever) generated clock, but use the divided signal as a clock enable. \$\endgroup\$ Mar 24, 2019 at 3:09
    \$\begingroup\$ @SimeonR - different receivers will have different tolerance for baud rate error. But your issue is likely sending the wrong things at the wrong times for the modem, not just baud rate. \$\endgroup\$ Mar 24, 2019 at 3:13
The issue was in fact a clock error as pointed out in the comments in my original question. There was a two clock cycle delay from when I pulled the transmission line from low to high to signal the start and then again from high to low to signal the stop (from one of my other entities that was responsible for the TX_READY signal being toggled). Digging up on the manual I found it uses a clock check to determine when its ready to transmit the data to the phone and the delays caused the modem to reset it's buffer and then transmit whatever it received, which because of the delay was nothing.
Thank you to users Sourabh Tapas and Chris Stratton for helping me identify these issues.
