-4
photo of PCB and desoldered capacitors
When I told a buddy that I am taking electronics courses and learning to manufacture simple homemade PCB boards, he found me a client with an interesting offer: To reverse engineer a small PIC controller board.
I never did reverse engineering before, but I am not too unfamiliar with the subject. I read materials on reverse engineering and decided that it's worth a try, especially since the client pretty much allowed me to abuse the probably-dead board as I see fit. Obviously I took a lot of pictures, including macro, found as many datasheets as I could and wrote down all the info on every component.
When it came to finishing the drawing of the PCB that I was doing in DipTrace, I knew I had to finish stripping down the board all the way, to study the circuitry a lot more closely and make sure I didn't miss anything hidden underneath the SMD components. (As it turned out, I missed many little details that were covered in thermal-glue and chunks of thermal rubber compound or something it was in originally.)
Now I had a good amount of mistakes during this process and I knew it, because this was the first actually serious job offer I had in this field. I just didn't know which mistake would show itself first. It was the unmarked ceramic capacitors. Around 7 or 10 of them, all roughly the same size (and I am pretty sure I lost one too).
Resistors were not a problem, they had numbers on them, and I had lots of photos to see where they would go on the board when I duplicate this one. My multimeter ran out of batteries and it took too much time to desolder and measure them and I really wanted to finish drawing the thing in CAD (I've been working on it for 2 days) so I just quickly stripped the board of all the remaining SMD components using a soldering fan.
Now I am not sure if I can place them in the right order, because while they are all the same size and same color. My dying multimeter with its unclear jumping numbers, hinted at the fact that they are not the same, as each cap was jumping around its own number before losing its charge to the multimeter (some are 30-40, others are 5-10 and so on). Maybe they are the same, but are at a different stage of holding the charge.
Anyway, I am guessing that if I solder them all to the same places they were originally soldered, using photos I took as a reference, wouldn't necessarily work. Any tricks that can help me? (I was thinking of first soldering everything back into its proper place EXCEPT for the caps and using surrounding parameters to see which should go where?) I also heard other people say that WITH MODERN electronics SMD caps it rarely matters, if they are around the same size physically. (Also there is a matter of the one I lost while poking it with a multimeter.) What are my options?
    \$\begingroup\$ ”I also heard other people say thaT WITH MODERN electronics smd caps it rarley matters if they are around the same size physically” Please stop listening to those people and educate yourself in the matter. \$\endgroup\$ – winny Mar 24 '19 at 8:33
The proper way to do this is to obtain another card. Remove the capacitors one at a time and measure them. Be sure that you have a working capacitor measuring tool. You can fake one easily if you can't find a dedicated meter.
Be sure to carefully document what value goes where on the board. Then obtain new capacitors of the correct values and put them back on the board.
Sometimes capacitor values matter, sometimes they are not critical. The only way to know for sure is to have a schematic diagram and a good understanding of how the various circuit elements operate. You can fairly quickly determine if a particular capacitor's value is critical or not.
The alternative methods of measuring capacitor values depend on what test equipment you have available. Most methods work best with an oscilloscope. Please modify your question and let us know what test equipment you have available. We can provide guidance when you tell us what you have to work with.
| improve this answer | |
  • \$\begingroup\$ Something like an ATmega will work.much better than a scope \$\endgroup\$ – Chris Stratton Mar 24 '19 at 6:59
  • \$\begingroup\$ That is definatley very useful information. i have an arduino lying around and osilloscopes are expensive. All i have now is a multimitere \$\endgroup\$ – CryptFS Mar 24 '19 at 19:35
  • \$\begingroup\$ Also The client said there are no schematics avaliable to this thing thats why i am reverse engineering this thing in the first place. They just need a few of these (the board is a boiler/heating euipment controller) but they are only avaliable if you either buy them along with the boiler equipment or wholesale of a few hundered from the supplier. But its a good learning experience for me anyway, thats why i agreed to this job in the first place \$\endgroup\$ – CryptFS Mar 24 '19 at 19:57
  • \$\begingroup\$ @Dwayne Reid Thanks for the solid advice, the client said he has a bunch of these dead boards lying around so he can give me another one if i need it. Next time ill be prepaired. (any advice on a capasitor tester for now? An oscilloscope is kinda out of my price range for now unless i get one of those cheap DIY kits) \$\endgroup\$ – CryptFS Mar 25 '19 at 2:56
