What is the reason that moving iron instrument could measure both AC and DC but moving coil instrument can't?
( moving coil can't respond quickly as the AC changes its direction so stays at zero - is the explanation i have listen till now )
i tried to get my doubt clear but couldn't find what i was searching for
  • \$\begingroup\$ Instead of listening to / waiting for answers why not do your own research. Figure out how each model works. Many things become obvious when you understand how things work. \$\endgroup\$ – Bimpelrekkie Mar 24 '19 at 10:56
  • \$\begingroup\$ i did research before posting it here..i have posted one of the place i searched for \$\endgroup\$ – DHRUV JOSHI Mar 24 '19 at 11:05
A moving coil meter uses a magnet and this naturally means that the needle moves clockwise for a positive current and anti-clockwise for negative current. The average effect (due to mechanism inertia) and an applied AC frequency of 50 or 60 Hz usually nothing i.e. zero perceptible movement.
A moving iron meter will attract an iron armature irrespective of the direction of the current hence, it will measure AC and usually will measure RMS AC quantities.
Not the answer you're looking for?Browse other questions tagged or ask your own question.
