It'd be of great use for us to emit correct rule check violations for power pins in IC we use. The logic is to force compiling failure when power pins of ICs are not driven correctly from power sources.
When we used KiCad Power pin could have been in or out hence when PowerIn pins where not connected to PowerOut pin an ERC error was emitted, but with Altium designer we only have Power Pin without direction.
The only violation on the matter is when input pins are not driven by output or power pin.
The only workaround we thought of is changing our ICs power pin to input pins, but we would really like to avoid that.
Are we missing something?
P.S. The hypothesis is of course that the violations are correctly signalled through project preferences in connection matrix and in error reporting tabs
It seems that you have a good understanding of the current state in Altium, and its limitations with power-pin ERC. What you state is indeed true (power pins do not have 'direction').
The only alternatives that I can think of with Altium, would be to use a hierarchical schematic setup where your power sources are all connected via sheet entries, and all power nets are configured as local.
You could then control what nets are input and output via the sheet entry properties. You may need to disable some of the default erc checking on 'power pins', because the power nets would now be reduced to 'normal' nets. However, errors on connection 'input' and 'output' nets would be caught using the normal mechanisms.
Another possibility is to cleverly name nets (and generous use of net-ties) to show that intended net-spokes are for input or output use. However, ERC would not catch any errors.
These solutions seem to me more complicated than the problem. I would recommend that you stick to the default strategy. Connecting up a supply backwards is really easy to notice, and should be on a checklist before starting the pcb layout.
  • \$\begingroup\$ Ok, so we did understand correctly ERC on PwrPins, and yes they would just be total overkills for the issue at hand. We will just continue keeping it on the checklists. Thanks \$\endgroup\$ – Shockwaver Mar 25 at 14:17
  • \$\begingroup\$ If you think that the above response is suitable, please mark the question as answered so I get my juicy internet points, and EE StackExchange remains orderly. \$\endgroup\$ – Chris Knudsen Mar 25 at 15:46
  • \$\begingroup\$ Ups.. sorry for having you asking for it! There u go... wanted to upvote but not enough juice 4 me yet XD \$\endgroup\$ – Shockwaver Mar 25 at 17:58
