The formula I've seen is to multiply the signal by its complex conjugate, then integrate across the time period interval, and then divide by the period. But when I do that I don't get A^2/2
  • \$\begingroup\$ Okay. So why don't you get \$\displaystyle \frac{A^2}{2}?\$ It would be helpful to know what you did so that we can tell you where you were incorrect. \$\endgroup\$ – KingDuken Mar 25 at 20:24
  • \$\begingroup\$ hi i posted my work and where im stuck \$\endgroup\$ – David Mar 25 at 20:33
  • \$\begingroup\$ im confused...shouldn't those terms be 0 if the final answer is to be A^2/2? \$\endgroup\$ – David Mar 25 at 20:40
  • \$\begingroup\$ isn't that the formula for power though? \$\endgroup\$ – David Mar 25 at 20:46
  • \$\begingroup\$ Sorry, misread the question AGAIN. I deleted my wrong comments. \$\endgroup\$ – DKNguyen Mar 25 at 20:50
The first image you posted appears to use Parseval's Relation after expressing the \$S_i(t)\$ as an exponential Fourier series.
Your method (the second image, I think) will produce the same answer, as long as you're careful about your limits of integration. Let's assume that you've defined \$T_0 = \frac{2\pi}{\omega_c+\omega_m}\$. Then your underlined terms can be recombined (using Euler "in reverse") to produce a cosine with frequency \$2(\omega_c+\omega_m)\$. This cosine will complete two full oscillations in \$T_0\$ seconds, so its integral is zero.
