I have a custom board using an Atmel SAM G55J (ATSAMG55J19A-AU) and I'm trying to get the SD card reader to work - which is connected to SPI0. I'm using the SD/MMC stack (set for SPI), as well as FatFS, available with ASF.
Following the example/demo code of the ASF's SD/MMC stack for the Atmel SAMG55, I made what I believe to be the necessary defines in order to communicate with the SD card reader throught SPI:
/** Enable SD MMC interface pins through SPI */
#define CONF_BOARD_SD_MMC_SPI
/** SPI slave select MACRO definition */
#define CONF_BOARD_SPI_NPCS0
/** FLEXCOM base address for SPI mode*/
#define BOARD_FLEXCOM_SPI    FLEXCOM0
/** SPI MISO pin definition. */
#define SPI_MISO_GPIO         (PIO_PA9_IDX)
#define SPI_MISO_FLAGS        (IOPORT_MODE_MUX_A)
/** SPI MOSI pin definition. */
#define SPI_MOSI_GPIO         (PIO_PA10_IDX)
#define SPI_MOSI_FLAGS        (IOPORT_MODE_MUX_A)
/** SPI SPCK pin definition. */
#define SPI_SPCK_GPIO         (PIO_PB0_IDX)
#define SPI_SPCK_FLAGS        (IOPORT_MODE_MUX_A)
/** SPI chip select 0 pin definition. */
#define SPI_NPCS0_GPIO        (PIO_PA17_IDX)
#define SPI_NPCS0_FLAGS       (IOPORT_MODE_MUX_A)
/** SPI Card Detect pin definition */
#define SD_MMC_SPI_MEM_CNT          1
#define SD_MMC_0_CD_GPIO            (PIO_PA18_IDX)
#define SD_MMC_0_CD_DIR             (IOPORT_DIR_INPUT)
#define SD_MMC_0_CD_MODE            (IOPORT_MODE_PULLUP)
#define SD_MMC_0_CD_DETECT_VALUE    1
#define SD_MMC_SPI                  SPI0
#define SD_MMC_SPI_0_CS             0
#define SD_MMC_0_CD_PIO_ID          ID_PIOA
In order to setup/initialize the SD card reader I created this:
void setup_peripherals(void)
    //Disable watchdog timer
    wdt_disable(WDT);
    ioport_init();  // call before using IOPORT service
    //Enable PIOA clock to detect Card Detect (CD) change
    sysclk_enable_peripheral_clock(ID_PIOA);
    //Setting SPI pins
    ioport_set_pin_peripheral_mode(SPI_MISO_GPIO, SPI_MISO_FLAGS);
    ioport_set_pin_peripheral_mode(SPI_MOSI_GPIO, SPI_MOSI_FLAGS);
    ioport_set_pin_peripheral_mode(SPI_SPCK_GPIO, SPI_SPCK_FLAGS);
    //Setting SD Card Detect pin
    ioport_set_pin_dir(SD_MMC_0_CD_GPIO, IOPORT_DIR_INPUT);
    ioport_set_pin_mode(SD_MMC_0_CD_GPIO, IOPORT_MODE_PULLUP);
    //Setting SPI chip select pin
    ioport_set_pin_peripheral_mode(SPI_NPCS0_GPIO, SPI_NPCS0_FLAGS);
    //Initialize SD MMC stack
    sd_mmc_init();
However, I don't seem to be able to detect that the SD card has been inserted since I get stuck here:
void WaitForSDCard(void)
    Ctrl_status status;
    //Wait until SD stack initialized and SD card inserted
    do
        //Check if stack ready
        status = sd_mmc_test_unit_ready(0);
        if (status == CTRL_FAIL)
            //Wait for a card to be inserted
            while (sd_mmc_check(0) != CTRL_NO_PRESENT)
                //!!!NEEDS A TIME OUT HERE!!!
    } while (status != CTRL_GOOD);
This happens because sd_mmc_test_unit_ready(0) keeps returning CTRL_NO_PRESENT, since sd_mmc_check(0) outputs SD_MMC_ERR_NO_CARD.
While I was trying to debug this problem/error I found out that sd_mmc_cards[0].state is initially set to SD_MMC_CARD_STATE_NO_CARD, which seems to be the default value for it. However the sd_mmc_select_slot(0) function changes the state to SD_MMC_CARD_STATE_DEBOUNCE which leads to sd_mmc_test_unit_ready(0) returning CTRL_NO_PRESENT.
Now, from my understanding the Card Detect should work similar to simple switch right? With that in mind, I tried to simply set the CD pin as an input using ioport and checking his level, however it simply returns 1 all the time (with or without card).
Any idea about what I'm doing wrong here?
  • \$\begingroup\$ Shouldn't you be checking the status continuously? I imagine that you want to react to status == CTRL_FAIL but if you aren't going to handle it, you may as well just keep refreshing the status AFAIK \$\endgroup\$ – FMashiro Nov 26 at 15:00
