So I'm looking at adding some LED mood lighting to our bedroom.
End game is to have a single LED strip controlled by 2 different switches
Currently, I have 2 switched 240V AC outlets, one either side of the bed, with each one feeding a 12v DC LED driver.
From this, I've got a short LED strip at bedside height. This works fine, as the left switch controls the left lights, and vice-versa.
I'd now like to add a strip at high-level, that is turned on when either side is switched on... I can take a feed from both drivers to the strip, however I suspect that if I just wire the LED strip into both drivers, then if I power on one side, then the power will leach through to the other side.
What's the best way to prevent this? A quick google suggests using a Diode, however I'm struggling to pick out the best option.
Is something like a SB560 the right choice? Or should I be looking for something different?
Cheers in advance for any replies.
I'm assuming you know the diodes go between the driver and the LEDs (not on the AC side).
And not knowing the LEDs current draw, the 5A spec of the suggested diode might be OK. Do you know the current draw?
Also, the diode presence will create a voltage drop - that gets worse with current (see spec sheet) so the LEDs might not operate normally (dimmer)
    \$\begingroup\$ Yeh, I'm intending on the Diode on the DC side of the driver. I've currently got a 50cm strip at low level, and the LED strip is rated at 12W/meter max. So worst case 0.5A per side currently... The high-level strip will be ~2.5m, so that's another 2.5A, so that's 3A per driver total... Dimming of the LEDs isn't a bad thing, as it's intended to be accent lighting rather than the main source. \$\endgroup\$ – fatmcgav Mar 27 '19 at 14:47
  • \$\begingroup\$ Sounds like it's worth a try \$\endgroup\$ – mike65535 Mar 27 '19 at 15:59
