I cannot se how the device is a buck charger when charging and a boost on the output. Am I stupid or is the datasheet wrong?
"5A Single Cell Li-Ion Switching Battery Charger with Direct Charge, Power Path Management and USB OTG Boost Mode " https://www.richtek.com/assets/product_file/RT9468/DS9468-01.pdf
Buck Regulator for Charging Battery.
= Stepdown from 5V to Battery (CC then 4.2V then cutoff)
Boost Regulator as OTG (on-the-go USB power)
= Step-Up from Battery to USB or 3~4V to 5V
It is consistent and correct.
I have redrawn the switches to show more clearly the topology used.
|improve this answer|||||
  • \$\begingroup\$ so the input("vbus") is the output in Boost OTG mode? \$\endgroup\$ – Anton Ingemarson Mar 27 '19 at 16:32
  • \$\begingroup\$ Yes Vbus is the output in Boost mode. Thus the design needs a Full bridge to change Vbat current direction and a bridge to swap PWM from series (Buck) to shunt mode.(Boost) \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Mar 27 '19 at 17:04
  • \$\begingroup\$ They don't really want you to understand how they designed it, just to use it. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Mar 27 '19 at 18:27
A synchronous buck converter, operating in continuous mode, will work just fine in reverse. In a lossless circuit, the PWM ratio plus the continuous conduction in the inductor enforces a voltage ratio from input to output, but lets current go either way. It's just a matter of how you arrange your control circuit.
  • \$\begingroup\$ So the input (Vbus) will be the output in boost mod? \$\endgroup\$ – Anton Ingemarson Mar 27 '19 at 16:35
  • \$\begingroup\$ I assume so -- it'd pretty much have to be, and it would fit with the notion of having a box that either takes 5V in and charges a battery, or puts 5V out. The datasheet is a bit light on that sort of detail. \$\endgroup\$ – TimWescott Mar 27 '19 at 18:25
