I have this part, which is the only component that has discernable discolouration, and which I would like to replace:
Photo of faulty IC
on the PCB of a non-functioning SMPS (12 V 3 A):
Photo of bottom of SMPS PCB
The only markings on it are '63 613' and a search shows up only this: New original power management chip 63513 63 513 63613 SMD 6 foot power IC straight shot, but no data sheets seem to be available (unless I need to be searching for something other than "63613").
Does anyone know of an alternative name/code/identifier for this IC? Or a suitable replacement?
Here is a better close up photo:
Closeup
closed as off-topic by Chetan Bhargava, Nick Alexeev Apr 23 at 2:32
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – Chetan Bhargava, Nick Alexeev
If this question can be reworded to fit the rules in the help center, please edit the question.
Looking for ic markings starting with 63, the OB2263 and twins HT2263 and another duplicate seem a very good candidate.
The first datasheet shows Marking Information "63 YWW" which would be 2006, week 13.
My assumptions:
  • Gate pin is connected by 22 ohm resistor and anti-parallel diode to a through-hole mosfet.
  • FB pin and GND pin are connected to through-hole optocoupler located below silkscreen text D4 (like TYPICAL APPLICATION in datasheet). Note C3 on the PCB is the capacitor close to the optocoupler in TYPICAL APPLICATION.
  • R5 and C1 form a RC filter connected to the SENSE pin
  • the through-hole component between silk R1 and R2 is an elco, and forms with R1 a filter for the power supply to the chip as in TYPICAL APPLICATION.
  • \$\begingroup\$ Thanks for the analysis. I have added an additional photo showing the 63613 more clearly \$\endgroup\$ – Greenonline Mar 28 at 3:00
