I am trying to understand the consequences (if any) of substituting a CR2450 battery for the specified CR2340 lithium battery in a small device. The device is constantly "on" and transmitting a signal, which is intended to be picked up by receiver based on proximity of the small device to the receiver. (When the small device is close enough to the receiver, a solenoid engages and stays on until the small device is again out of range.)
My hope is that -- because they have the same voltage and current rating -- the CR2450 will work and provide much longer battery life in the small device than the CR2430, but I just don't know enough to understand the impact of the specs that are different for these two batteries.
As mentioned, the CR2450 and the CR2430 have the same "nominal voltage" (3.0V) and the same "standard current" (0.2mA) ratings.
Physically, they are the same diameter (24.5mm), but different heights (CR2450 = 5mm; CR2430 = 3mm). [However, height won't be an issue here].
The difference in these two batteries' "nominal capacity" ratings (CR2450=600MAh; CR2430=270mAh) are the reason I hoped the CR2450 would last about twice as long as the CR2430.
BUT, they have different ratings for "continuous current (maximum)" (CR2450=1.0mA; CR2430=3.0mA) and "pulse current (maximum)" (CR2450=15mAh; CR2430=20mAh), and I just don't know whether or how either or both of those spec differences relates to this proposed battery substitution.
So can someone help me understand "continuous current (maximum)" and "pulse current (maximum)" with respect to batteries, and particularly how those spec differences might produce any practical differences if I substitute a CR2450 battery for the CR2430 battery that this small device was designed to use?
Thanks
    \$\begingroup\$ My first reaction is to not worry about it, just do it. If this were a critical medical device or something, I'd avoid the risk of malfunction. But I think it's harmless to try out the thicker battery. For toys, I've done this substitution countless times over many years without any problems. The worst that happens is that the thicker battery will have somewhat higher internal resistance and your device either will work over a shorter range or else won't work. If so, lesson learned at very little cost to try it out. But if it works, you are probably golden. \$\endgroup\$
    – jonk
    Mar 27, 2019 at 23:31
  • \$\begingroup\$ "The device is constantly "on" and transmitting a signal" - what is the average and peak current draw of your device? \$\endgroup\$ Mar 28, 2019 at 4:46
  • \$\begingroup\$ Sorry, but I don't know the current draw for the device. How would I measure that? \$\endgroup\$
    – pdalton
    Mar 28, 2019 at 23:30
I finally got a moment to check some datasheets and write. I figured someone else would cover this by now, too. But no. So I'll start by pointing out the more important bits of the datasheets to examine. I'm referencing these: Energizer CR2430 and Energizer CR2450:
The basic things to verify are the chemistry and the voltage (as an aside, the chemistry usually determines the single-cell voltage.) Beyond that, you can verify that their operating temperature ranges are the same (and so they are.)
Once that's done, just look at the "Typical Capacity" shown for the two parts. As you already pointed out, the CR2450 has more capacity than does the CR2430. At first blush, this alone suggests that the CR2450 will run longer. Just as you'd hoped.
But there's a second thing to check. Note that the CR2430 says that this capacity is "rated at \$15\:\text{k}\Omega\$ at \$21^\circ\$C" while the CR2450 says that this capacity is "rated at \$7.5\:\text{k}\Omega\$ at \$21^\circ\$C"! The CR2450 rating is for twice the load! This not only confirms the fact that you really can actually expect the CR2450 to run longer, but that the capacity figure might even be a little bit better, loaded more lightly as the CR2430 specification indicates for its capacity rating.
That said, your own device (being a transmitter) is likely using more than the specified continuous drains (CR2430 at \$190\:\mu\text{A}\$ and the CR2450 at \$390\:\mu\text{A}\$.) You also don't know exactly the minimum operating voltage for your device and that affects how long the battery is still useful. So it's possible that you won't get the difference in duration you might expect, comparing the typical capacity figures.
Regardless, it's fairly certain that if you can get around the differences in thickness, you will be okay and you will almost certainly get more duration out of the CR2450.
  • \$\begingroup\$ Thanks a lot for the conclusion that the swap should work! I couldn't see where your continuous drain #s came from, and I still don't understand the import of he "continuous current (maximum)" and "pulse current (maximum)" specs, but at least I'm much more comfortable that I won't hurt the device by trying out the battery swap! \$\endgroup\$
    – pdalton
    Mar 28, 2019 at 23:36
  • \$\begingroup\$ @pdalton I don't recall you referencing a datasheet; instead, quoting from one I can't go read. The datasheets I linked don't show what you quoted. So I can't comment much unless you point me to where you got your information. But otherwise, yes, there should be no problem. \$\endgroup\$
    – jonk
    Mar 29, 2019 at 1:33
