11
While repairing a Marantz amplifier using the service manual, I came across resistors with odd symbols (see page 18). They are trapped between two parallel lines (for example, 3297).
Is this linked to the fact that this is a 0.33W resistor? A comment suggested it could be related to the way it's mounted to the board for heat dissipation, but I don't see any mounting difference between 3297 and 3283 (see picture below).
Furthermore, what's the difference between the "R" and "E" letters for 3293 & 3305. Don't they both mean "Ohm" ? Is there any reason for Marantz to use both notations in this diagram or is it just an inconsistency?
Marantz PM-68 Main circuit left amp +56V Marantz PM-68 Main circuit photography Marantz PM-68 disassembled
  • \$\begingroup\$ Check electronics.stackexchange.com/questions/246920/…. Weird they use both in the same schematic. \$\endgroup\$
    – Huisman
    Mar 28, 2019 at 9:56
  • \$\begingroup\$ That's why it bothers me. Why would they use both if they mean exactly the same thing? \$\endgroup\$
    – MFlop
    Mar 28, 2019 at 10:10
  • \$\begingroup\$ Possible duplicate of What is a "100R" resistor? \$\endgroup\$
    – C. K.
    Mar 28, 2019 at 10:11
    \$\begingroup\$ @MariusGulbrandsen : I'm just bothered by the fact they used both notations. The main question was about the two parallel lines for 3297. \$\endgroup\$
    – MFlop
    Mar 28, 2019 at 10:15
    \$\begingroup\$ @soosaisteven Don't write answers in the comment section. No one can interact with them, and OP can't mark anything as accepted. \$\endgroup\$
    – pipe
    Mar 28, 2019 at 16:12
crop from schematic supplied in the question, showing the unknown resistor symbol
(Crop from the original schematic, showing the unknown resistor symbol.)
Answer: That is one of the (many) symbols used for a fusible resistor. Here is an extract from page 177 in the book: Electronics for Service Engineers by Joe Cieszynski and David Fox (Google Books link to page 177) showing that symbol, which I've marked in red below:
Figure 11.4 from "Electronics for Service Engineers" by Joe Cieszynski and David Fox
