I know that it interferes with torque somehow? But is there anything else? Thanks so much for taking the time to answer.
closed as unclear what you're asking by JRE, Finbarr, RoyC, laptop2d, Elliot Alderson Apr 1 at 14:25
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ A statement that ends in a question mark is still a statement. Ask a question, or make a statement, or do both seperately. \$\endgroup\$ – JRE Mar 28 at 11:54
  • \$\begingroup\$ Perhaps if you first investigate why a motor even uses a magnet. \$\endgroup\$ – Marla Mar 28 at 15:29
Stronger magnets change the characteristics of the motor. This may improve the motor or it may not depending on what you want the motor to do.
Torque develops in an electric motor from the magnetic fields of the rotor attempting to align with the magnetic fields of the stater. The stronger the magnetic field the stronger the force. So a stronger magnet allows for greater torque.
The trade off is max speed at a given voltage. This is because a stronger permanent magnet means more magnetic field lines cutting across the copper windings increasing the back emf for a given speed..
