6
I'm an electrician and my work is to maintain boats.
I have a problem. On the boats are sailing lights, and for each sailing light is another light inside the boat that tells you if the sailing light is working or not.
This was no problem with the old 40W incandescent light bulb but now all the lights are LED and the trick doesn't work any more.
This is the sailing light I'm using:
  • Hella marine. NAVILED PRO TOP. 2LT 959 908-5.
  • Operating Voltage 9 to 33V DC
  • Power Consumption Less than 2W (0.14A@12V / 0.08A@24V)
So this is what a have on the drawing on picture 1:
  • H1 is the sailing light.
  • D1 is the indicator light and will only shine if the sailing light is okay.
  • D2 is only to drop the voltage be 0.7V.
Picture/designs 1 and 2:
Design 1 Design 2
Picture/design 3:
Design 3
EDITS: And here is how I ended up doing it, and it seems to be working :) Thanks for all your help! enter image description here
    \$\begingroup\$ In your first diagram, make D1 a zener diode with polarty reversed.. For a White or blue LED, use a 3V3 or 3V9 or 4V7 1 Watt zener. For lower voltage LEDs use a 2V7 or 3V3 or 3V9 zener. | Choose R1 to suit current in LED. eg with a white LED at 3V, 5 mA say and 3V9 1 Watt zener. I LED = (Vzener - VLED)/R1. Higher zener voltages take more voltage away from main light BUT make LED current more stable. Here I_LED = (Vz-Vl)/R1 or R1 = (Vz-VLED)/ILED . eg (3.9-3.0)/5ma = 0.9/.005 ~+ 180 Ohms. \$\endgroup\$
    – Russell McMahon
    Mar 29, 2019 at 10:43
4 Answers 4
One comment on Neil's answer: If the load does draw a current surge the LED is still at risk because there is a low resistance path through the base, a resistor is needed in series with the base.
An alternate circuit would use a PNP to sense the current and drive a LED connected to ground for minimal voltage drop but some extra current usage. Looking at the question again, picture 2 shows this but with base and emitter reversed and a resistor needed in series with the base.
According to the specs, your sailing light draws 80mA at 24v. So let's redraw it as a current source.
This means you have 80mA available in the cabin to drive your indicator light. You could use a sufficiently beefy LED that will tolerate 80mA, and simply put it in series.
If you have to use a lower current LED, then the following transistor shunt will reduce the indicator LED current to a value that gives a 0.7v drop across R1. For instance, 35 ohms will give you a LED current of around 20mA, when there's more than 20mA being drawn by the circuit. Make sure the transistor collector current and total dissipation are adequate to shunt the remaining current. It would probably be best to use a very beefy transistor for Q1 in case your sailing light draws a lot of current on startup.
  • \$\begingroup\$ If the load does draw a current surge the LED is still at risk because there is a low resistance path through the base, a resistor is needed in series with the base. An alternate circuit would use a PNP to sense the current and drive a LED connected to ground for minimal voltage drop but some extra current usage. Looking at the question again, picture 2 shows this but with base and emitter reversed and a resistor needed in series with the base. \$\endgroup\$
    – EinarA
    Mar 29, 2019 at 11:51
  • \$\begingroup\$ That's an excellent start, but I'd also be concerned about a wiring fault that might ground the emitter of Q1. This would instantly blow the LED by putting 24V across it through the BE junction of Q1. I'd add some resistance (or better still, a polyfuse) in series with the wire to the lamp to limit the current to a value that Q1 can handle. Of course, the LED would remain lit under this condition, so perhaps another transistor+LED could be used to indicate this kind of fault. \$\endgroup\$
    – Dave Tweed
    Mar 29, 2019 at 11:57
  • \$\begingroup\$ Thank you 'Neil_UK' for the drawing. Okay based on that drowning I can see that 0.7v / 35ohms is 0.02A, but what if a have a 3V or 5V indicator LED? How can I calculate the right voltage? \$\endgroup\$ Mar 29, 2019 at 14:44
  • \$\begingroup\$ @ÖrvarSigþórsson I really hope that is a typo in your last comment, since you are talking about boats. \$\endgroup\$ Mar 29, 2019 at 14:48
  • \$\begingroup\$ And to answer your question, the circuit doesn't control the indicator LED voltage, it controls its current directly. It doesn't matter what the voltage rating is -- although if it is anything more than a "bare" LED, it will subtract more from the voltage available to the navigation light. Fortunately, the light you mention seems to have a switching regulator and can tolerate a wide range of supply voltages. \$\endgroup\$
    – Dave Tweed
    Mar 29, 2019 at 15:06
One improvement to EinarA's answer would be to add one more transistor. Q2 cuts off the indicator light if a wiring fault shorts out the navigation light.
In other words, Q1 turns on at about 60 mA of load current, but Q2 cuts it off again at anything over 650 mA.
  • \$\begingroup\$ I also gave some thought to indicating an over load, but my idea was to increase the current so the LED was much brighter. This could be accomplished with a resistor in series with the emitter and reducing R3. At normal current this emitter resistor would determine brightness and at high current R3 would set intensity. \$\endgroup\$
    – EinarA
    Mar 30, 2019 at 0:20
This is an intergral, bulbless LED fixture. The bulb isn't going to change. The ship's voltage isn't going to change. As such, the current that will flow is knowable. It does have an internal PWM power supply, so inrush current is a possibility.
So I see a couple of options.
Simply put the indicator in series with the lamp and you're done.
The key is to choose an indicator that is happy with the series current (<160ma at 12V, <80ma at 24V, plus inrush) and won't take too much of a bite out of voltage (you have not 3V to spare in a 12V system, so non-red LEDs are out). 160ma at any LED voltage is an awful lot of light; maybe a parallel resistor can have most of the current bypass the LED.
If the inrush current damages the indicator, I'd say you need a better indicator.
Sense current on each lamp feeder, e.g. with a reed switch.
Say a reed switch operates at 10 ampere-turns. So for instance on a 24V (80ma peak) that's 125 turns for 10At, double it to 250 for sure detection.
If you are detecting for multiple lights, you can wire all the reed switches in series and bring them out to one indicator light. Any light failing to draw current will snuff the indicator, making you walk the boat to find which one.
Given that it's on a boat, I would "prototype" it onto a terminal block on a bit of stiff project board, test it as good, then "pot" it in West System epoxy. Maybe put a spare or two on the board, each brought out to the terminal blocks.
