I've been searching for awhile and can't find an answer so hopefully someone here can help me :)
I just want to know if leaving a servo motor idle, powered but no input, is bad for it? I'm planning on leaving a servo motor powered indefinitely and only sending it a signal to move a bit maybe once a day.
I was trying to setup something with a relay so my microcontroller can control the power to the servo but it's a little bit of a pain, not that it can't be done.
So, should I definitely not leave my servo motor powered for days/weeks? Thanks!
  • \$\begingroup\$ Note that there is a difference between no signal, and a signal with a steady pulse width. If you expect the servo to hold position, you really should be providing a signal; behavior without might usually be to hold position, but that isn't really guaranteed. \$\endgroup\$ Oct 7, 2012 at 15:48
This is just like any other motor really, if you're running it inside spec it should be fine. Its lifetime isn't indefinite though. I've done a couple of days with no problems.
  • \$\begingroup\$ Alright, I'll give it a go. It's a crappy "Micro Servo 9g A0090". Came with some stuff I got for my Arduino. \$\endgroup\$
    – AnEE
    Oct 7, 2012 at 0:03
