I've got Ripple Carry adder (26bit) made from scratch.
entity Ripple_Carry26 is
port(
A, B : in BIT_VECTOR(25 downto 0);
Sum : out BIT_VECTOR(25 downto 0)
end entity;
Now I want to use it to update counter every time clock goes up. Counter is just simple register
entity Counter is
port(
inp : in BIT_VECTOR(25 downto 0);
clk : in BIT;
qout : out BIT_VECTOR(25 downto 0)
end entity;
architecture Reg of Counter is
begin
proc : process(clk)
begin
if clk'event and clk = '1' then
qout <= inp;
end if;
end process;
end architecture;
If I use port map to just connect stuff, it doesn't make sense, I only want to use the adder when clock goes up, but if I use process and say something like
if clk'event and clk='1' then
I'd like to say something like "now use the adder and add 1 to it" but I'm not sure how.
(I know I'm doing it too complicated, it's all learning purposes)
Every idea helps!
