For my degree work, i make some reseaches for different bus systems and i've found ethernet a bit different than others: The old 10Base5 and 10Base2 ethernet used only one pair of conductor to communicate the nodes with each other (coaxial cable) and implemented CSMA/CD to avoid/manage transamission collisions. Thats fine. However modern twisted pair ethernet equipments more likely connected as point to point devices with full-duplex capability, where there's no collision, but still implements CSMA/CD.
It is possible to create an ethernet bus line using only one twisted pair? Or this one conductor line connection is possible only for the old coaxial ethernet?
Is it possible to create an ethernet bus line using only one twisted pair?
Absolutely Yes. It won't be a bus as 10basex is, but will be point to point as most Ethernet implementations are today.
Read up on IEEE Std 802.3bw-2015 100BASE-T1 –Automotive Environment
This is a 100Mbps link over a single twisted pair.
You can also get out to 1000Mbps using IEEE Std 802.3bp-2016 1000BASE-T1 –Automotive and Industrial. Good for router powered ethernet based sensors.
This might be a good place to start, and it provides pointer to the newer SPE standards allowing both signal and POE over a single twisted pair.
