6
I have created the following circuit to better understand how to use a transistor as a switch*.
I've been struggling with understanding datasheets for transistors.
Datasheet states EB maximum voltage
According to the datasheet the emitter-base maximum voltage is 6.0 V. In my circuit I am only applying 5 V. From reading the datasheet (below) would you expect that to be too much?
Also, I see that the secondary (output) circuit of collector-emitter can supposedly take up to 40 V(?). Does that mean I should be able to drive a circuit on the collector-emitter side that has up to 40 V on it?
Am I reading the datasheet properly?
I'm wondering because in my other (referenced question) circuit the transistor became very hot with only 5 V -- but that may have been due to being wired improperly, I'm not sure.
2N2222a max ratings
You can see the complete datasheet at:
https://www.onsemi.com/pub/Collateral/P2N2222A-D.PDF
* Note This question is directly related to Is it possible to use a NPN BJT as switch, from single power source?. However, I had the original circuit built improperly there, and I'm now wondering if the 2N2222 can take 5 V on its base pin (according to the datasheet).
  • 4
    \$\begingroup\$ Visualize a diode where the arrow is in a BJT. The transistor will inherently constrain the base voltage to be at most one diode voltage (0.7V) above the emitter. Here you're trying to apply 5V. To limit the current, add a base resistor. The resistor will be 5V on one side and 0.7V on the other. \$\endgroup\$
    – BB ON
    Apr 1, 2019 at 18:35
    \$\begingroup\$ Everyone "always mentions 0.7V" because the base-emitter junction is a PN junction exactly like a diode. It becomes forward biased at that voltage and there it is essentially at maximum conductivity. Applying 5V can't "turn it on" more. The base resistor defines the current allowed to enter the base. By applying a small base current, you get a large collector-emitter current gain. Please read BJT theory. \$\endgroup\$
    – BB ON
    Apr 1, 2019 at 18:46
    \$\begingroup\$ No problem. A quick solution is to just add a resistor between SW1 and the base. Try 1K. \$\endgroup\$
    – BB ON
    Apr 1, 2019 at 18:57
    \$\begingroup\$ You accepted my answer to your previous question, which explained why you need a resistor in series with the base. In your comment you said you had built my proposed circuit and it worked. Why are you trying without a base resistor again? \$\endgroup\$ Apr 1, 2019 at 20:18
    \$\begingroup\$ @raddevus 0.7V is about the amount of "bias voltage" must exist across a silicon diode before it stops blocking and starts passing normal current. It's due to the material used to make the semiconductor. For a diode made out of germanium, this bias voltage would be about 0.3V. I'm learning, too. \$\endgroup\$
    – Suncat2000
    Apr 2, 2019 at 15:30
6
Bi-Polar transistors multiply current. A small current from the Base to Emitter causes a large current from the Collector to Emitter. On the ON Semi Datasheet, see hfe on page 2 for the gain, which is between 50 and 375 for this transistor. Realistically it is probably ~ 200. This means that if you have a current flow of 1 mA in the base-emitter, there will be a current flow of 200 mA through the collector - emitter.
The Base Emitter junction is a small diode with a reverse breakdown voltage specified at 6 V. This circuit has no reverse voltage, BUT with 5 V on the Base and ~ 0.7 V drop across the B-E junction, you will have 4.3 V into a short circuit (~ 0.05 Ohms for wiring) which is 56 Amps / 369 Watts! Neither the transistor or the power supply will last more than a microsecond.
That is why you MUST PUT a current limiting RESISTOR in series with the BASE. A value of 430 Ohms would be ~ 10 mA Base current, but.... Use a standard 1.5k (1.47k) Ohm which will allow 2.67 mA Base current which means the Ic current will be ~ 534 mA (with Hfe =200). This is less than the 600 mA Ic allowed by the data sheet. The 200 Ohm resistor will limit the LED-C-E current to 14.5 mA.
Hope all is correct, the last time I did these calcs was over 40 years ago.
  • \$\begingroup\$ Thanks very much, this definitely adds to my understanding and may be the most appropriate answer to this question since it references the datasheet -- I was also curious about that 600mA max rating that I saw there and you explained that too. \$\endgroup\$
    – raddevus
    Apr 2, 2019 at 11:56
27
This is your circuit drawn as a schematic to read for understanding rather than as a wiring diagram (which is more about getting everything connected and not so much for understanding it.)
The idea illustrated in your diagram, where the LED and a current-limiting resistor are placed in series in the collector circuit, is a common (and reasonable) approach. The BJT is operating as a "semiconductor switch" and this is one of several approaches for that behavior. So far, so good.
But the idea of directly tying \$+5\:\text{V}\$ to the base, when the emitter is also nailed down to ground, is not common and it's not good. This directly places a full, forward-biased \$5\:\text{V}\$ across the base-emitter diode. Keep in mind:
  1. You only need from as little as \$600\:\text{mV}\$ to perhaps as much as \$900\:\text{mV}\$ (in most cases) to use the BJT as a switch.
  2. For each additional \$60\:\text{mV}\$ (typically) you will get 10 times as much collector current (if permitted by the circuit portions connected to the collector) and 10 times as much base current (always possible.) Broadly speaking, the base current will be exponentially related to the applied forward-biasing voltage across the base and emitter.
You were applying \$5\:\text{V}\$!! This is way, way, way above what you should have been using. So the BJT was being literally flooded with base current. Of course it was getting hot! It was dissipating serious power. Might have even damaged the device (I'd probably throw the part away, in fact, after doing something like that.)
This is why a resistor is often applied to the base circuit.
The base resistor's voltage drop is a simple linear relationship to the current passing through it. The BJT's base-emitter junction current is an exponential relationship. So as the BJT's base-emitter diode junction tries to rapidly increase it's current, the resistor in series with it opposes this rapid change by dropping voltage. Very quickly, it will turn out that the resistor drops enough voltage so that the base-emitter junction's voltage is close to where it should be.
By using a resistor, you permit the base voltage to "find a stable and reasonable voltage drop" for its operation.
As others have pointed out, the Maximum Ratings section also specifies an absolute worst case reverse-biased voltage for the base-emitter. This is because the base-emitter PN junction diode can't handle a lot of reverse-bias voltage in a typical BJT. Diodes used in bridge rectifiers can often handle very large reverse-bias voltages across them. But not so much with BJTs. They aren't designed to handle much of that kind of stress. Instead, they just break down and avalanche. So the ratings there tell you what to watch out for. Often, people will add a separate diode (oriented opposite to the forward direction of the base-emitter junction of the BJT) going from base to ground in a case like this to protect the BJT ... just in case.
  • \$\begingroup\$ Fantastic explanation. Very clear and helped me understand a lot. Thanks. \$\endgroup\$
    – raddevus
    Apr 1, 2019 at 19:35
    \$\begingroup\$ @raddevus Thanks for the kind words and I'm glad it helped out. \$\endgroup\$
    – jonk
    Apr 1, 2019 at 19:38
  • \$\begingroup\$ Note that that 600-900mV would be doubled in the case of a Darlington transistor. (of course, the semiconductor used also changes the voltage, but silicon is the only one that matters in modern electronics. That may change, silicon carbide is becoming popular, but for now it's all silicon.) \$\endgroup\$
    – Hearth
    Apr 2, 2019 at 2:45
    \$\begingroup\$ @Hearth If the OP had mentioned a Darlington configuration, or Szlikai, I suppose I would have said something more, including slower response times, and so on. But without a hint otherwise, I might have just confused the OP by listing out a table of possibilities that made no sense to the OP and couldn't be put into useful context for the question. I'm kind of glad I didn't mention it, to be honest. ;) \$\endgroup\$
    – jonk
    Apr 2, 2019 at 3:19
    \$\begingroup\$ @RichS - although in fact they are both voltage controlled. \$\endgroup\$ May 1, 2020 at 23:30
15
\$V_{EB}=V_E-V_B\$.
The datasheet is saying the emitter can be (up to) 6 V above the base, not that the base can be 6 V above the emitter.
With \$V_{BE}\$ (\$V_B-V_E\$) at 6 V, an absurdly large current will flow into the base and burn out your transistor very quickly.
    \$\begingroup\$ @raddevus: To be clear - \$ V_{EB} \$ is the maximum reverse voltage the base-emitter junction can withstand (where forward is the normal base current direction). \$\endgroup\$
    – Transistor
    Apr 1, 2019 at 18:10
