I can't find any information which PCM data format is better - I2S or Left-Justified and why I should use one format over another. Is there a difference or it doesn't matter which one I'll use?
closed as primarily opinion-based by Chris Stratton, Finbarr, laptop2d, Bimpelrekkie, PeterJ Apr 5 at 11:45
Many good questions generate some degree of opinion based on expert experience, but answers to this question will tend to be almost entirely based on opinions, rather than facts, references, or specific expertise. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ If you need to talk to something that only supports one, pick that. Otherwise up to you. \$\endgroup\$ – Chris Stratton Apr 1 at 21:35
  • \$\begingroup\$ As written this is opinion based. There also does not appear to be any prior research and no details on what PCM is being used to interface with, which might affect answers. \$\endgroup\$ – David Apr 1 at 21:36
Neither is better, unless there are some limitations in the used devices regarding the protocol. Select something that both devices can support.
