What are the precautions I should be aware of when using different transceivers on a CAN bus?
What I can think of:
  • They neeed to operate at the same voltage (on CAN_H and CAN_L)
  • They need to have some common baudrates (at least one)
Is there anything else?
For example I would like to use both these transceivers on the same CAN bus:
    \$\begingroup\$ As it happens I use exactly those 2 on the same buses all the time. Microchip has a newer part MCP2561 which is pin compatible though, just better. \$\endgroup\$
    – Lundin
    Commented Apr 2, 2019 at 15:14
  • \$\begingroup\$ I'm doing CAN for a hobby project and the MCP2551 is easier to find and a little bit cheaper. You are right to point that Microchip recommends to use the MCP2561 instead. \$\endgroup\$ Commented Apr 3, 2019 at 7:57
The whole reason why we have such standards / specifications as CAN bus is to eliminate / avoid the potential issues you mention.
The transceivers simply need to adhere to the CAN bus specification which they do as both transceivers meet the ISO-11898 standard physical layer requirements, i.e. CAN bus. This specifies the voltages on CAN_H and CAN_L so no need to worry about that.
It is up to you (the user) to configure the speed of the transceivers in such a way that both can work together. For example a device might not support the same data rates as the other device. It is up to you to select the data rate which all transceivers support.
