I have a 50 ohm BNC cable which connects to a coaxial connector on a PCB.
I want to invert the signal from the cable with an op amp.
If I use the top circuit from the image, will the cable be terminated correctly, or should I add a buffer with high input impedance like the circuit in the bottom of the image to achieve 50 ohm termination ?
  • \$\begingroup\$ Explain why you believe you need to terminate the cable in 50 ohms. What signal frequencies are you using? \$\endgroup\$
    Apr 3, 2019 at 10:30
  • \$\begingroup\$ @Andyaka , hello my signals are around 50 Mhz . The termination must be done to 50 ohms according to the datasheet of the bcn cable. Best regards \$\endgroup\$
    – Chris Sy
    Apr 3, 2019 at 10:32
You will more-than-likely get away with scenario 1 but if you were to be picky you would terminate in 52.63 ohms: -
52.63 || 1000 = 50.
Nearest value to 52.63 ohms is 52.3 ohms and this, in parallel with 1 kohm gives 49.7 ohms i.e. 0.5% away from perfection.
  • \$\begingroup\$ So , i have to use a resistor which will be equivalent (or close to 50 ohms) when put in parallel with the 1k . Than you very much Sir \$\endgroup\$
    – Chris Sy
    Apr 3, 2019 at 10:39
