I'm a releative newbie. I'm using an Arduino to control a Cowlacious audio board that uses the ISD1700 chipcorder series of chips. Periodically, I need to pull the reset pin on the chipcorder to ground to reset it to it's original state. It seems to me that with the low currents involved I should be able to do this directly, but I'm not having luck. Using an Arduino pin set to digital out and leaving it HIGH except when switching doesn't work (I assume the chipcorder doesn't like the voltage when it's high). How can I get this to work?
P.S. I know I could use a transistor as a switch, or some sort of relay, but do I need to do that?
