I made an integrated library using altium form my personal usage. Everything was OK but today when I want to use this library I get this error while try to use some of the components.
[File Access Error] Connector Library.IntLib Could not access PCB library in file: G:\Work\Personal\Altium\Connector Library\Project Outputs for Connector Library\Connector Library.IntLib
When I add the component to schematic, there is no problem but when I try to move design to PCB the component has no footprint.
I have done the following but nothing changes:
  • I changed the file path
  • Recompiled the library
protected by Community Sep 23 at 16:14
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
