The board has two PWM inputs, see:
Do I have to use four pins to control two motors? Thanks
This board is to control ONE motor, it seems to have two BTS7960 half-bridges forming full bridge. Each of half-bridges must be controlled accordingly, using four pins. How? There is a Google for this, see this instructables for example. Here is the standard application circuit for the typical board, from BTS7960 datasheet:
DIR signals, should go to R_PWM & L_PMW. AND PWM should go to both L_EN, R_EN. You can check it, it works )
The board controls a single motor.
Pins 1 & 2 - Power for the motor
Pins 3 & 4 - Direct connections to the motor
A - Ground for the 5 V controller
B - 5 V for the controller
C & D - Overcurrent indicators
E & F - Reverse and Forward enables (can tie both to B, if desired)
G & H - PWM controls
To drive motor in reverse, put a pulse train (up to 25 kHz) on pin E.
To drive motor forward, put a pulse train up (up to 25 kHz) on pin F.
You can only control one motor with this board.
You connect your motor in the M+ and M+ connectors (The letters are written in the bottom layer of the board near the correspondent green connectors)
The battery is connected in the B+ and B- connectors (The letters are also present in the botton layer of the board).
The RPWM pin is used to rotate the motor in one direction using a PWM signal
The LPWM pin is used to rotate the motor in the opposite direction of the RPWM pin also with a PWM signal.
The R_REN When is at 5V (HIGH) is used to activate the RPWM pin.
The L_REN When is at 5V (HIGH) is used to activate the LPWM pin.
The maximum voltage for the RPWM,LPWM R_EN and L_EN pins is 5V.
With a 12V motor you only need the 4 pins listed above to control a motor with this board.
You don't need to connect the VCC pin to 5V when You use a 12V battery in B+ and B-. For battery values below 12V i'm not sure.
The GND pin is wired to B-.
The R_IS and L_IS are used for current sensing. No need to use them in simple projects.
You can control this board with an Arduino and may good idea to isolate the control pins of the Arduino with Optocouplers.
