Hello I am trying to communicate that is using SMBus. So when I try to send a data which was 0x0D and address of the device was 0x16. I see something like that on the data line:
And this is how my clock (SCL) pin looks like:
So my questions are :
- Is this data and clock signals look normal? I know data is not normal because I cannot transmit the message but what about clock signal?
- So Data looks like 1 1 1 1 1 1 .... 1 1, is it because I cannot ack ACK/NACK from slave, it keep sending the data over and over again? Or maybe something else behind this strange data signal.
- I used 20 K pull up resistors for SDA and SCL for 5 V Vdd. (For SMBus I think I should have used 15 k ohm.) Can it be the reason? Or any other ideas that causes this? Thanks beforehand
In the datasheet of the battery that I try to communicate, it says:
So I thought I could use 20 k ohm as pull up resistors.(to be honest I could not really understand what they say in the document..)
And this is how SCL/SDA signals look like together
This is the circuit schematic (I use RB1 and RB2 for SMBus communication.)
This is the pin diagram for the battery. I am communicating with the first section, PINS 1-4:
