I am using a NUCLEO-F401RE board as a master and a B-L072CZ-LRWAN1 as a slave communicating over UART.
Slave is configured to receive in interrupt mode using HAL_UART_Receive_IT. Master is programmed to request data to the slave with a blocking function using HAL_UART_Transmit inside a timer interrupt callback.
Master is asking for data to slave every minute and the protocol is working fine, but I want the code to work no matter what happens with the boards, so I am turning off both boards (one at a time) to see if everything works fine when they turn on again (to recover from any sort of error in the system).
Communication between them stops working when I turn off the slave (let me explain). If master tries to communicate when slave is off, it gets stucked in HAL_UART_Transmit function so even when I turn on slave, communication never happens again.
Does anybody knows what is happening?
Here is pin configuration:
Master
/**USART1 GPIO Configuration
PA9 ------> USART1_TX
PA10 ------> USART1_RX
GPIO_InitStruct.Pin = GPIO_PIN_9;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_LOW;
GPIO_InitStruct.Alternate = GPIO_AF7_USART1;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_10;
GPIO_InitStruct.Pull = GPIO_PULLUP;
Slave
PB6 ------> USART1_TX
GPIO_InitStruct.Pin = GPIO_PIN_6;
GPIO_InitStruct.Alternate = GPIO_AF0_USART1;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
GPIO_InitStruct.Alternate = GPIO_AF4_USART1;
