Currently, the numbers in xxx.mt0 file are with 3 decimal place (example: 1.331e-07). I was wondering if I can set a flag in .sp file to increase the accuracy.
  • The .OPTION INGOLD controls the format of numbers in printouts.
  • The .OPTION NUMDGT=x controls the listing printout accuracy.
  • The .OPTION MEASDGT=x controls the measure file printout accuracy.
In your case, you should change in .OPTIONS.
  • \$\begingroup\$ It worked. Just to add to this information: range is 0 to 10, numdgt=4 is the default. \$\endgroup\$
    – Shannon
    Apr 5, 2019 at 20:14
  • \$\begingroup\$ Bravo.. and I just looked up an answer and have zero experience on Hspice \$\endgroup\$ Apr 5, 2019 at 20:45
