I have to use a TFT panel but I have never used any before and I really can't get how it works and how I can interface it with a microcontroller.
I found INT057ATFT which seems to have an integrated TFT controller so I guess I just interface it with the 8080 interface of my microcontroller.
But I have been advised to use a TFT like the TM056KDH01 and this one I really don't get how I can interface it with a microcontroller. On the pin descriptions I don't even see the RGB pins.
Could you explain me how these screens work and how to use and interface them? For the microcontroller I will choose it depending on the screen I take so I don't have made my choice yet. I will take something which is possible to interface with the screen.
Another thing is: is there any advantages using one or the other type?
After some research I found out that it would not be easy to interface a tft panel with an RGB digital interface with the microcontroller. Then I thought about using a tft controller and I found the SSD1963 which seems great because it can drive tft with a resolution up to 800/480 but it needs 3.3V supply AND 1.2V supply.
Does anyone know about another controller with the same caracteristic but with only the 3.3V supply?
