I am sampling a signal on the STM32F3 Discovery board (stm32f303vct6) with two ADCs working in interleaved mode. It works great with a 200kHz 1V sine wave. But when I apply 10kHz 100mV sine wave, I see some interesting patterns. ADCs seem to convert all the voltage levels in a specific gap into a single number. It is like sampling in lower resolution. When you see the images below it will be clear.
I have also tried to run ADCs in independent mode and triggered them with 2 synchronized timers but still, the pattern is there. I don't encounter this problem when only one ADC is sampling.
Images:
1 Sampled signal with interleaved mode
2 Samples of one of the ADCs
Sample code:
#include "stm32f30x.h"
//#define DUALDMA
void sysinit();
void clockconfig();
void delay(int d);
void adcinit();
void dmainit();
void dualdmainit();
int main(){
    sysinit();
    clockconfig();
    #ifdef DUALDMA
    dualdmainit();
    #else
    dmainit();
    #endif
    adcinit();
    RCC->AHBENR |= RCC_AHBENR_GPIOEEN; // GPIOE enable
    RCC->AHBENR |= RCC_AHBENR_GPIOAEN; // GPIOA enable
    GPIOE->MODER = 0x55555555; // GPIOE -> output
    GPIOA->MODER |= 0x0000FFFF;// GPIOA -> analog
    // Reset SRAM memory area
    for(int i = 0;i<1024*4;i+=4){
        *((uint32_t*)(0x20000800+i)) = 0;
    ADC1->CR |= ADC_CR_ADSTART;
    while(1);
void delay(int d){
    // Dummy delay
    int l = d*1000;
    for(int i = 0;i<l;i++);
void adcinit(){
    RCC->AHBENR |= RCC_AHBENR_ADC12EN; // Enable ADC clock
    RCC->CFGR2 |= RCC_CFGR2_ADCPRE12_4;// ADC clock prescaler = 1
    ADC1->CFGR |=  ADC_CFGR_CONT; // Continous mode
    ADC1->SQR1  |= ADC_SQR1_SQ1_0 ; // ch 1
    ADC2->SQR1  |= ADC_SQR1_SQ1_0 ; // ch 1
    ADC1_2->CCR |= ADC12_CCR_DELAY_2 ; // Delay = 4 (5 Cycles)
    #ifndef DUALDMA
    ADC1_2->CCR |= ADC12_CCR_MDMA_1; // If single DMA is selected, configure MDMA bits for 12 bits
    #else
    ADC1->CFGR |=  ADC_CFGR_DMAEN;
    ADC2->CFGR |=  ADC_CFGR_DMAEN;
    #endif
    ADC1_2->CCR |= ADC12_CCR_MULTI_2 | ADC12_CCR_MULTI_1 | ADC12_CCR_MULTI_0; // Interleaved mode
    //ADC1_2->CCR |= ADC12_CCR_CKMODE_0; // Does not seem to change anything
    ADC1->CR &= ~(ADC_CR_ADVREGEN_1 | ADC_CR_ADVREGEN_0); // Enable VREG
    ADC1->CR |=  ADC_CR_ADVREGEN_0;
    delay(500);
    ADC2->CR &= ~(ADC_CR_ADVREGEN_1 | ADC_CR_ADVREGEN_0);
    ADC2->CR |=  ADC_CR_ADVREGEN_0;
    delay(500);
    ADC2->CR |= ADC_CR_ADEN;
    ADC1->CR |= ADC_CR_ADEN;
    while( (ADC1->ISR & ADC_ISR_ADRD) == 0 );
    while( (ADC2->ISR & ADC_ISR_ADRD) == 0 );
void dmainit(){
    // DMA config for Single DMA, 32 bits
    RCC->AHBENR |= RCC_AHBENR_DMA1EN;
    DMA1_Channel1->CPAR = (uint32_t)&ADC1_2->CDR;
    DMA1_Channel1->CMAR = 0x20000800;
    DMA1_Channel1->CNDTR = 1024;
    DMA1_Channel1->CCR = DMA_CCR_EN | DMA_CCR_MINC | DMA_CCR_MSIZE_1 | DMA_CCR_PSIZE_1;
void dualdmainit(){
    // DMA config for DUAL DMA, 16bits
    RCC->AHBENR |= RCC_AHBENR_DMA1EN; // DMA1 Enable
    RCC->AHBENR |= RCC_AHBENR_DMA2EN; // DMA2 Enable
    DMA1_Channel1->CPAR = (uint32_t)&ADC1->DR;
    DMA1_Channel1->CCR = DMA_CCR_EN | DMA_CCR_MINC | DMA_CCR_MSIZE_0 | DMA_CCR_PSIZE_0;
    DMA2_Channel1->CPAR = (uint32_t)&ADC2->DR;
    DMA2_Channel1->CMAR = 0x20000800+1024*2;
    DMA2_Channel1->CNDTR = 1024;
    DMA2_Channel1->CCR = DMA_CCR_EN | DMA_CCR_MINC | DMA_CCR_MSIZE_0 | DMA_CCR_PSIZE_0;
void clockconfig(){
    // External oscillator (HSE): 8MHz
    RCC->CR |= RCC_CR_HSEON; // Enable HSE
    while( (RCC->CR & RCC_CR_HSERDY) == 0 );
    RCC->CFGR |= RCC_CFGR_PLLMULL9; // PLL MUL = x9
    RCC->CFGR |= RCC_CFGR_PPRE1_DIV2; // APB1 Prescaler = 2
    RCC->CFGR |= RCC_CFGR_PLLSRC; // PLL source = HSE
    FLASH->ACR |= FLASH_ACR_LATENCY_1; // Two wait states
    RCC->CR |= RCC_CR_PLLON;  // Enable and wait PLL
    while( (RCC->CR & RCC_CR_PLLRDY) == 0 );
    RCC->CFGR |= RCC_CFGR_SW_PLL; // Select PLL as system clock
void sysinit(){
    //STM32F303 reset state
    /* Reset the RCC clock configuration to the default reset state ------------*/
  /* Set HSION bit */
  RCC->CR |= 0x00000001U;
  /* Reset CFGR register */
  RCC->CFGR &= 0xF87FC00CU;
  /* Reset HSEON, CSSON and PLLON bits */
  RCC->CR &= 0xFEF6FFFFU;
  /* Reset HSEBYP bit */
  RCC->CR &= 0xFFFBFFFFU;
  /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE bits */
  RCC->CFGR &= 0xFF80FFFFU;
  /* Reset PREDIV1[3:0] bits */
  RCC->CFGR2 &= 0xFFFFFFF0U;
  /* Reset USARTSW[1:0], I2CSW and TIMs bits */
  RCC->CFGR3 &= 0xFF00FCCCU;
  /* Disable all interrupts */
  RCC->CIR = 0x00000000U;
  SCB->VTOR = 0x08000000; /* Vector Table Relocation in Internal FLASH */
    \$\begingroup\$ The schematics is more important than the source code \$\endgroup\$ – pipe Apr 5 at 14:38
  • \$\begingroup\$ I don't encounter this problem when only one adc is sampling. But you get another problem, it looks like you are missing samples and the graph program draws a straight horizontal line. \$\endgroup\$ – Steve G Apr 5 at 14:43
  • \$\begingroup\$ @pipe i can sample the signal correctly when i use single adc so i don't think there is a problem with the schematic. And the samples here are obtained on STM32F3 Discovery board. \$\endgroup\$ – itlki Apr 5 at 14:44
    \$\begingroup\$ @SteveG I think there is a misunderstanding here. Both graphs have the same signal. First graph shows the combined samples, all the data, secnod graph shows half of the data (sampled by one adc but still in interleaved mode). When i turn off the second adc and run first ADC in independent mode, those horizontal lines disappear. \$\endgroup\$ – itlki Apr 5 at 14:49
    \$\begingroup\$ Ok, but if the internal MUX keeps switching in and out capacitors to feed your signal to each internal ADC in turn, this may affect the signal. It doesn't happen when you're not MUXing stuff. The devboard doesn't seem to buffer anything. We don't know what you connected to it and it's easier if you just explain your setup from the beginning instead of everyone here asking "what's your source impedance", "which pins are you using", etc \$\endgroup\$ – pipe Apr 5 at 15:01
