I don't know much about electricity. I live in an old building experiencing bizarre electric phenomenon. The building might have bad wiring, I live near elevators and power distribution for the entire building in a large multi-floor building. I hear a faint humming sound through the wall 24/7 - sounds like electricity buzzing. At first, I somehow thought there was bad wiring or being near the electrical equipment was causing an excessive amount of electricity. But the more I dug into it, I think its a peculiar static electricity problem. I experienced static shocks when touching an old heater or other metal.
I notice small jolts in my bed. My theory is that the air is very dry, carpets are 100% polyester and it is pulling static electricity into my polyester mattress. The bed is now sitting on the ground because the metal frame was worse. Basically, if I place my hands and feet together on the mattress, I feel these tiny jolts in the mattress and I think they are transmission of electrons to the carpet or ground. The sheets attract a ton of lint. I think the static is flowing through the mattress or accumulating in the mattress and it feels like something is pulsating in the mattress. When I add in the humming sound, I wonder if electricity is somehow spreading into the room which then flows to the carpet. Either way, it feels like some electricity is accumulating in the air, being pulled to the polyester carpet/mattress and charging there. Ultimately, this is also being attracted to the polyester in the mattress and accumulating there. So if you lay in it or press really hard, you feel like its being shot through to the floor very gently. Similar to Morse code with small jolts to the ground. Where can static electricity come from and can there be enough to cause a sensation such as that?
Is it even possible for electricity to "spread" from the power distribution, wires or elevator power or be spread out from the power of the elevators or the old wiring through the floor or walls to create this jolting sensation? Where is it all coming from? How would enough electrons be constantly generated 24/7 on a consistent enough basis that you feel the small spasms through the mattress at virtually anytime. Could the described circumstances be caused by static electricity with polyester carpets, polyester mattress (20%) and generally dry air? It's a tiny zap. Like the static is building up in the mattress and then zapping to the carpet through my back or feet when standing on the floor.
