I am currently designign a 4S2P Li-Ion battery pack. The cells I use are unprotected, so I want to use one of those BMS/Protection/Balance boards like this:
https://www.ebay.de/itm/4S-40A-16-8V-40A-18650-Li-ion-Battery-Batterie-BMS-Protection-Board-mit-Balance/264137388088?hash=item3d7fd0b038:g:EcMAAOSw5e5cd1Qe
I want to include the charging in my project and all these boards talk about being "charging boards" and specifying a "charging voltage".
Do I assume correctly, that those boards do not implement proper CC/CV charging procedures?
If I want balanced charging, and my protection board provides balancing, would I be able to charge the pack by using a CC/CV circuit to apply a charging voltage to the entire pack?
I'm also thinking about not using balancing, since I have new identical cells.
closed as off-topic by Nick Alexeev Apr 5 at 18:38
  • This question does not appear to be about electronics design within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Please post this question to the eBay seller. EE.SE isn't his volunteer application support. \$\endgroup\$ – Nick Alexeev Apr 5 at 18:38
It doesn't look like it has a CC/CV only balancing, hook the charger up to the CF-4S30A board
Here is a video that shows how it works:
enter image description here Source: https://www.mikrocontroller.net/attachment/379678/610606910_1_1000x700_kontroler-bms-3s-4s-25-30a-zaryada-razryada-zaschity-balansir-dlya-li-ion-vinnitsa_rev003.jpg
  • \$\begingroup\$ I see. Would external CC/CV circuit work together with the balancing circuit connected? I've read, that some chargers periodically switch between charging and balancing \$\endgroup\$ – Hendrik410 Apr 5 at 18:36
LiIon cell charge voltage is not fixed. First, because variations in battery chemistry lead to differences in the proper charge termination, and second, because you can make a choice to charge the cells to a slightly lower voltage and get more charge cycles in return for lower capacity, or you can choose to charge the cells to a slightly higher voltage and get the opposite trade.
