is it possible to add some kind of a remote control receiver to a basic audio amp board that only has a manual volume knob? The IC chip in the amp board is a TDA7498. A general view of the board is in the imageamp board
    \$\begingroup\$ Not easily. You'd need an MCU to decode the remote commands, then then either find a place where you can control volume with an analog level, find a sufficiently wide-range digipot to insert, or even add a servomotor to move the volume knob - a feature actually seen on some stereos. \$\endgroup\$ – Chris Stratton Apr 5 at 22:29
  • \$\begingroup\$ thanks a lot for the comment/ info Chris, I'll look into the mcu and digipot sugestin. Yeah I considered the servomotor but would be nice if I could manage a more electronic (than mecanical?) solution \$\endgroup\$ – gevi_alex Apr 7 at 1:11
