I have simulated the following circuitry in LTSpice:
Input Voltage pulse characteristics:
Questions: 1. What is the reason for the current spikes on the input resistor R2? Do I need to worry about this?
This is the corresponding current output on R1:
  1. When driving an nchannel mosfet, my understanding is I need to use a push-pull transistor pair to be able to feed in more current to the mosfet to overcome its gate capacitance. But, in simulation, when I use just an npn transistor, the current output is the same as the push-pull pair. Is my circuit wrong?
    \$\begingroup\$ Have you considered the charge storage parasitics of the BJTs? \$\endgroup\$
    – jonk
    Apr 7, 2019 at 11:49
    \$\begingroup\$ For (2)both circuits are driving the same unrealistic load. Put 1 or 2 nF across the load (to represent that gate capacitance) and try again. \$\endgroup\$
    – user16324
    Apr 7, 2019 at 12:23
  • \$\begingroup\$ tie your collectors to +- 10 volts, place a 100 ohm Rload to Ground, and make the input be 1MHz sinusoid centered about ground, at 2 volts PP. \$\endgroup\$ Apr 7, 2019 at 15:09
