I have a challenge in connecting a 240 V, 3-phase, 9 kW machine to a 3-phase, 415 V supply in Uganda. The machine is from South Korea. The phase monitor trips.
Below is the brief precaution information for the installation of the machine
This equipment requires a lot of power consumption, so it must be installed in a dedicated line power source.
(AC 240 V, three-phase, 50Hz) Install in 9 kW or higher power line.
Equipment must be connected directly to the equipment through a dedicated switchboard.
Do not put a plug into the outlet.
Connect directly to a dedicated switchboard or distribution board.
Connect directly to the switchboard using the power cord attached to the equipment.
If the 3-phase power connection is not properly connected, the equipment will not work.
If the power line change message is displayed on the screen and the buzzer sounds, the power line connection is wrong.
The supply is 415 V.
