I'm designing a circuit in Eagle and I need to have fixed dimensions on certain holes. I can of course use the dimension tool to measure the distance but I don't see a way to make the dimension "stick" to the hole I'm designing.
Is this possible? So that I can make the dimension tool measure from the hole to the side of the board and then when I move the hole the dimension follows?
