I was doing this circuit which I found on the Internet. My question is what is the logic behind the functioning of this circuit? Thanks!
    \$\begingroup\$ How about a link to wherever you found it? \$\endgroup\$
    – JRE
    Apr 9, 2019 at 14:11
You press the button, it rings the bell and turns on the light for a set amount of time if it's dark outside.
IC2 is almost certainly a 555 timer chip.
