The following is the logic circuit: enter image description here
I have to simplify the following:
(((AB)')'+(B+C)+(AB)'(B+C)')C
=(AB+B+C+(A'+B')(B'C'))C
=(B+C+A'B'C'+B'C')C
=BC+C+A'B'C+B'C
=C+A'BC'+B'C
closed as off-topic by Dave Tweed Apr 10 at 11:31
  • This question does not appear to be about electronics design within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ Draw a truth table for both - the original and the result. Compare. Note that the final expression can be further simplified. \$\endgroup\$ – Eugene Sh. Apr 9 at 15:28
  • \$\begingroup\$ Actually I'm given a logic circuit and have to simplify the expression in order to get the truth table. \$\endgroup\$ – Jarvis Ferns Apr 9 at 15:32
  • \$\begingroup\$ You can get a truth table from a non-simplified expression. This one is a bit complicated, but not a big deal. You can fill up half of it right away noting the AND with C of the whole expression. \$\endgroup\$ – Eugene Sh. Apr 9 at 15:34
  • \$\begingroup\$ Unless I'm reading the parenthesis wrong, the answer is just C. Everything is or'ed with that inner C + B, then and'd with C. Are you sure you copied it down correctly? \$\endgroup\$ – yhyrcanus Apr 9 at 19:02
  • \$\begingroup\$ @yhyrcanus I added the logic circuit and made some changes \$\endgroup\$ – Jarvis Ferns Apr 9 at 19:25
You still messed up your initial statement.
((A NAND B) XOR (B OR C)) AND C
((AB)'(B+C)' + ((AB)')'(B+C))C
Note it's an AND between the ((AB)')' and the (B+C).
I hope you can get it from there. Still highly suggest making a truth table. It's super obvious what the answer is if you draw out the truth table.
  • \$\begingroup\$ Thanks a lot! But I was unable to create a truth table first, so i finished the simplification. \$\endgroup\$ – Jarvis Ferns Apr 9 at 20:49
(((AB)′)′(B+C)+(AB)′(B+C)′)C
=(AB(B+C)+(A′+B′)B′C′)C
=(AB+B′C′)C
=ABC+B′C′C
=ABC
    \$\begingroup\$ Not mine, but I suspect it's the lack of words. Welcome to SE.EE too :) \$\endgroup\$ – awjlogan Apr 10 at 8:16
