Is the following question correct?
Consider the Boolean expression F(A,B,C) = ABC+ AB+ AC.
Implement this logic expression using one 4x1 multiplexer. Do not use C as an input to the selectors of the multiplexer.
Also,Can someone give me a hint or push me in the right direction,as i was thinking of using the above method? Thanks in advance
  • \$\begingroup\$ It took me a while to realize that the picture illustrates a method, not the same problem described in the text. \$\endgroup\$ – Dave Tweed Apr 9 at 22:01
No, I wouldn't use that method. Instead,
  • Simplify the given function
  • Since you can't connect C, connect A and B to the select inputs of the multiplexer.
  • Figure out what needs to be connected to each of the four multiplexer data inputs. The choices are 0, 1 or C.
