-1
I'm looking to produce a pure sound on one frequency to be played via a timer to come on at intervals over a six week period. this is for an undergrad dissertation. would an arduino work and could it be fitted to a timer that would turn the sound on remotely? with thanks
  • \$\begingroup\$ would an arduino work : Yes. could it be fitted to a timer that would turn the sound on remotely: Yes. You need to ask more specific questions if you hope to get more detailed answers. Simply prefacing this with "How would I ..." would be too broad. \$\endgroup\$ – brhans Apr 10 at 12:07
  • \$\begingroup\$ If a "square wave sound" is sufficient the arduino will be suitable, but "one frequency" sounds like you might want to produce a sine wave. Does "remotely" mean that you want to trigger the sound wirelessly or just using any interface? \$\endgroup\$ – Sim Son Apr 10 at 12:09
Yes, but you have some design decisions to make:
Sleep or no sleep
You need to decide if you want the Arduino in those 6 weeks to sleep (using less power), or be fully active all the time. The latter is simpler, but it will use some current during those 6 weeks, to be active for a short time.
Timer
Different possibilities:
  1. You can use a timer, however, I doubt if the timer can handle a long period of 6 weeks. In case you want to sleep, you need to store a counter each time the timer elapses and store it in EEPROM in case you want to have the Arduino in sleep mode, or in a variable when you do not want the Arduino to sleep.
  2. Alternatively, you can use a RTC to set an alarm, and use the alarm to either wake up the Arduino (using a GPIO pin to be HIGH/LOW), or activate a function or timer.
  3. Also instead of the timer, you can use a big delay (sleep function), but only if you want the Arduino to never sleep.
Check if the accuracy is enough in all cases.
Buzzer
For the buzzer, you can easily use an external component. There are plenty of examples how to control this using a frequency and time.
