After a research on MOSFET use, I've found that I'm unable to connect load on Source in N-type without additional consideration.
About this component CPC1002N http://www.ixysic.com/home/pdfs.nsf/www/CPC1002N.pdf/$file/CPC1002N.pdf
I've a MOSFET driven by a LED, N-Type. This component is described as Relay, in this case should I take in consideration that load still need be on Drain becouse there's MOSFET inside? Or can I put load where I prefer since Vgs is given by an optocoupler?
A mosfet (so, also in the solid state relay) has a substrate diode that conducts when the source potential is higher than the drain potential. So, care should be taken how to connect the "load".
When you have a SSR made off two mosfets arranged back-to-back with their source pins tied together, their substrate diode are anti-series and it will not matter how the "load" is applied.
  • \$\begingroup\$ So, as I understood, doesn't matter if in CPC1002N I have a diode as gate or there's relay written on datasheets. It acts like a normal MOSFET with optoisolated activation. \$\endgroup\$
    – Singed
    Apr 11, 2019 at 12:55
