I am using a stm32f407vgtx to control full bridge drivers which drive a H bridge of 4 N-channel Mosfet. I don't have any idea about grounding. I am thinking of using two separate ground AGND (ground of 5V ) and PGND (power ground 24V) then I will connect them together with a Net Tie.
_ am i on the right path. _ Any advice or reference can help me (grounding consideration).
Thank You.
Best Regards
  • \$\begingroup\$ A schematic would really help to understand your question. Usually the output clamps of a h-bridge are not grounded, but I don't think that's what you are asking for... \$\endgroup\$ – Sim Son Apr 11 at 16:11
  • \$\begingroup\$ You don't want your 24V power currents to flow in your 5V logic grounds. A single point connection between the 2 grounds will prevent this. If you highlight the high current paths on your schematic, it should help you find the best location to connect the 2 grounds. \$\endgroup\$ – Mattman944 Apr 11 at 16:48
  • \$\begingroup\$ @ Mattman944 . Thank you but I don't know how to find the location to connect them can you help plz. \$\endgroup\$ – B.walid Apr 12 at 9:47
  • \$\begingroup\$ @ Sim Son .thank you \$\endgroup\$ – B.walid Apr 12 at 9:48
  • \$\begingroup\$ Search for the concept of „star grounding“ on this site or elsewhere. You will find a lot of info. \$\endgroup\$ – Stefan Wyss Apr 12 at 16:10
