The charges move from negative (hot wire) to positive/negative (neutral) to make the device work right? So why would the Short occur only when they are directly connected? Wouldn't they just flow freely to Earth? Or it's different when DC passes the neutral line? Or Because it was weaken by the transformer after passing the device?
2\$\begingroup\$ Technically, a short is any connection that bypasses a load (like a short-cut). So if you connect the hot-wire to the neutral, the current still bypasses the load no matter where it ends up so that is still a short. It doesn't matter if the current return path is on the neutral or the ground/earth. It's still shorting across the load and still pulling a lot of amps. \$\endgroup\$– DKNguyenApr 11, 2019 at 16:58
1 Answer
Why short circuit occur when the hot line touches the neutral wire (aka ground)?
The neutral wire is not and should not be "also known as ground". They serve different purposes.
No. You are asking about an AC circuit (live, neutral and protective earth) so the current and voltage alternate. Polarity changes at the mains frequency, 50 Hz or 60 Hz, depending on your location.
"Short" in electrical jargon is an abbreviation of "short-circuit". This is analogous to a short-cut on a journey. The current flows through the short-circuit instead of through the intended load.
This question is unclear.
We're mixing up DC and AC terminology here.
A short-circuit can occur on a system with no earth connection. Short circuits can occur in a torch (flashlight) that is floating in space if a fault causes one power supply wire to touch the other.
In most AC electrical systems one wire is bonded to Earth at the local transformer and is, therefore, "neutralised". You should never read a high voltage on it. This means that there are two means of current returning from the live wire to the source: either through the neutral (normal way) or through the earth (during a fault).
