Please forgive my ignorance in my description. I have looked around and been unable to find what the following symbols mean: on wire number 51 there is a black filled circle with a dashed circle encompassing wires 1868 and 1869 going to the hall effect sensor. What does this mean? Also, what does the "sideways Z" symbol across those wires mean?
\$\begingroup\$ Awesome! Thank you so much! \$\endgroup\$– TriedandDiedApr 12, 2019 at 3:56
\$\begingroup\$ Shielded twist pair with shld connected to the dot. \$\endgroup\$– Tony Stewart EE75Apr 12, 2019 at 5:20
1 Answer
I'm fairly sure that the symbol means that the position sensor low and high lines are shielded (probably) twisted pairs, the shield being the grounded wire number 51.
