Assuming the instructable schematic works okay, you can use the same values for the base resistors as for the 2N3904, there is not much difference between the transistors or the shift-register output current capacity.
I believe the transistors are only on one at time, and the absolute maximum Vcc current is 70mA, and absolute maximum continuous output current is 35mA implying a resistor value well above about 65 ohms or maybe above 130 ohms.
The other 74HC595s are being abused more severely since I believe all 8 can be on at once, which implies an absolute maximum peak current per LED of less than 9mA. With 100 ohms the current would be about 18mA if the 74HC595 output was perfect. At 7.8mA the Vol is guaranteed to be 150mV typical so it's almost certainly going to exceed 9mA (the absolute maximum limit) with all LEDs on that chip illuminated.
The consequence of this will likely be shortened life of the CMOS chips. It may not be a big deal for a toy that is kept in a benign (ie. cool) environment.
The 74HC164 is rated for even less current (20mA per output and 50mA total through Vcc or GND) so you're better off than the original, for what that's worth.
As you are probably aware, the 74HC595 does require an additional strobe signal (RCLK). You may be able to simply invert SCLK and feed it to RCLK to get a similar result (or not, I've not looked into it deeply).
