I added the >NAME attribute to the footprint of a device and now the names are not shown on the board.
I have already tried to update the library (with library --> update all) and also the replace function.
But when I place the same part again the name is shown, only the old ones wont update, even with the replace function the names are still not shown.
  • \$\begingroup\$ CTRL-click on all the parts affected (to select all) and use the replace function to apply to all parts selected. \$\endgroup\$
    Apr 12, 2019 at 10:40
  • \$\begingroup\$ @Andyaka Like I said, the replace function is not working, doesn't matter if I select one by one or as a group. \$\endgroup\$
    – rene025
    Apr 12, 2019 at 10:48
Now I found the answer myself.
When the REPOSITION tool is selected, click on the parts where the name is missing and then the name shows up. Also when a group is selected it's working, just right click and Reposition:Group.
More infos about the problem can be found here: https://forums.autodesk.com/t5/eagle-forum/changes-made-to-gt-name-in-footprint-not-propagating-from/m-p/8557215/highlight/true#M20265
Click in the scematic or layout editor on Library -> update all
  • \$\begingroup\$ That is what I have tried first. It is not working for the Text parts. \$\endgroup\$
    – rene025
    Apr 12, 2019 at 12:07
  • \$\begingroup\$ Ok, this is weird. I just tested it and it works for me... \$\endgroup\$
    – jusaca
    Apr 12, 2019 at 13:04
