enter image description hereI'd like to drive high side and low side MOSFET for buck converter, so I have used IR2184s,(the image bellow) to do the job,
The frequency of oscillation is 1Mhz, so DRVR is a square wave signal of 1MHz frequency and 5V peak. VBATT=23V and the other components are shown in the image, The duty cycle is 50% and the mosfet used to be driven id IRF540
My circuit doesn't work as expected, (ie: I do not get a squar wave at bothe HO and LO)
I have recalculated the value of C6 but this doesn't solve the problem, and I don't know why ?? enter image description here
    \$\begingroup\$ show a sketch of the actual waveform. is duty cycle not 50%? are rise and fall times not ZERO_time? Do actual waveforms (from scope photos) have ringing? \$\endgroup\$ – analogsystemsrf Apr 13 at 10:52
    \$\begingroup\$ I would use more than 100nF at Vcc of U1. Keep C33 (as close as possible to U1) and add 1uF closest to U1. Since you power it with a battery, it is likely there are long leads between the battery and U1 and other components fed by the battery. So, you might need more caps on other places. \$\endgroup\$ – Huisman Apr 13 at 11:17
The turn-on propagation delay is typically 680 ns and worst case 900ns. When driving at 1 MHz 50% duty-cycle,\$ t_{on}\$ = 500 ns. So, you already turn off the gate driver, before it could drive LO or HO high.
So, this IR2184 is too slow to be driven on 1 MHz.
Next, without connecting the low-side mosfet, the bootstrap cap will not be charged, and therefore the high side driver will not work.
