I am trying to convert sine wave of 50 Hz and 10 mV to square wave of 10 mV of positive side only.
I used the following circuit. But the square wave has higher voltage compare to my requirement.
What changes are need to make in this circuit?
  • \$\begingroup\$ Several points:LT1017 needs a minimum supply of 1.5V. It also has a typical saturation voltage of 5mv, so your output is unlikely to be from 0V to 10mv. Your input is shown as 100mV but the question is for 10mV \$\endgroup\$
    – user131342
    Apr 13, 2019 at 11:55
  • \$\begingroup\$ Just to make sure I understand, you are operating the LT1017 with a supply voltage of 200mV and the simulation says you get an output voltage of 312mV? Is this Multisim? \$\endgroup\$ Apr 13, 2019 at 11:56
Your simulator is lying to you. The LT1017 cannot operate on a power supply of just 200 mV. It needs a minimum of 1.1 V.
Therefore, you need to take the full-swing output that it produces and attenuate it back down to the level you require.
