I think that the code below is wrong because it uses blocking (=) instead of non-blocking (<=) assignments but since there is only one statement in the always block is this an issue?
Also, it is sensitive to op but it also updates op within the always block, will this create some sort of loop condition?
Are there other problems with it?
always @ (a or op)
begin
  op = a + b;
end
You are using (reading) b and it is not in the sensitivity list.
op should not be in the sensitivity list but it does not hurt.
It is strongly recommended to use always @( *) in these cases.
The assignment is correct and should be blocking.
