I am constructing a circuit where 2 microcontrollers will communicate with a high or low state on their IO pin. Basicly a state pin for Bluetooth connected, or not. One microcontroller will have an IO pin as an output and the other an IO pin as an input. I know my microcontroller has an internal pull up (also pull down) resistor, but how does this circuit look like? Below is how I want to connect it, for sure I shouldn't need to have resistors when there are internal ones, right?
So my real question is how does the internal pull up/down resistors look in the microcontroller? Is it like this?
